I have the same problem. The light status does not update when the light turns on. I’m able to turn off the light using custom automation (which turns off all the lights). So I’m figured the gateway accepts the commands but HA cannot read the current status from the Tradfri gateway.
Restart of HA fixes the problem temporary. I’m not sure after how many hours or days the problems start. Seams to work no for the last 2 or 3 days (HA version 0.70.1).
Going to search for the current Tradfri firmware version, will update this post.
Same problem here. Switches in HASS return to on no matter which state the bulbs are in.
The only way the state changes is trough Developer tools -> States. And even here I experience a peculiar issue.
I turned off a light and that worked trough States, but then I tried switching the group off and it did switch it off but broke the page of the Web UI where the switches were shown. The error I get when opening the mentioned page is “Service system_log/write called”.
I’m at work right now so I don’t have access to logs. I can paste them here later in the evening, so maybe someone will have an idea of what is the issue with these lights/gateway integration.
I’m also having this intermittent (seems daily) Tradfri GW service problem and its getting annoying. I notice the GW is still pingable from my mobile today, though the app reports as not connected. So networking on the GW seems to be working (at least at the ICMP level) but not the services that rely on it.
A temporary reboot workaround for me, will be to connect it to a smart plug and have some rule that reboots it. But this is inconvenient to set up, uses expensive hardware (unless I get a Sonoff in there) and is not how an infrastructure device should be operated. IKEA should be fixing this pronto as it seems to be affecting a lot of customers.
Does IKEA have a bug tracker? Googled, but nothing shows.
It’s 2021 now… Did anyone find a solution yet? I’m running 1.15.55 and my gateway crashes just about once every 24 hours of so. No ping replies at all yet just before it starts to stop replying I noticed:
PING ikeahomesmart (10.0.0.48) 56(84) bytes of data.
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=1 ttl=128 time=0.571 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=2 ttl=128 time=0.366 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=3 ttl=128 time=0.358 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=4 ttl=128 time=0.341 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=5 ttl=128 time=0.340 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=6 ttl=128 time=0.343 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=7 ttl=128 time=0.364 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=8 ttl=128 time=0.366 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=9 ttl=128 time=0.332 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=10 ttl=128 time=673 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=11 ttl=128 time=11671 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=13 ttl=128 time=10553 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=14 ttl=128 time=9513 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=17 ttl=128 time=7393 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=19 ttl=128 time=5313 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=22 ttl=128 time=2193 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=23 ttl=128 time=2192 ms
64 bytes from ikeahomesmart (10.0.0.48): icmp_seq=24 ttl=128 time=1191 ms
