Does anyone know if these bulbs can be paired with the Aqara Gateway (lumi.gateway.v3) and if they can then be controlled by Home Assistant?
Hi, I am looking for the same information.
I know they work with the twin version of the hub, the Xiaomi Gateway, but since I am switching to Aqara hubs to gain Homekit compatibility, it is interesting, also for me, to know if I can add Ikea Tradfri bulbs to the system.
thanks
I ended up buying one of these to see if it would work. I reset it as per the instructions on an IKEA YouTube video but it’s not picked up by the Mi Home app on Android or IOS. There seems to be a bug on the IOS app as the 30 second timer does not start counting down when it’s trying to detect the bulb. I’ll try again when the apps are next updated but so far it’s not looking too hopeful.
I got an answer from Aqara, meanwhile…
I am sorry to reply you so late.
I am sorry to tell you that the current IKEA lamp is not compatible with Aqara Hub. After that we will do it compatible with IKEA lamps.
Kind regards.
sounds they will implement compatibility later on, but still unsure if the ikea bulbs will be exposed to homekit (most likely not)
Will look into zigbee2mqtt as a stopgap
