I am trying to figure out how to configure the tradfri lights in HA.
When I set up HA, it automatically detected my tradfri gateway and added all the lights in a “tile” group called group.all_lights with the friendly name “Light”.
Now I’ve made a group with my light groups and would like to remove/hide/move to Lights to it’s own tab.
But I can’t find it defined anywhere! I’ve checked the whole configuration.yaml file, groups.yaml and customize.yaml but it’s nowhere to be found.
The only reference I see to tradfri is this:
tradfri:
host: IP HERE
api_key: API KEY HERE
allow_tradfri_groups: true
(the code is working, I just failed at indention here)
Last command is just to get the groups from Tradfri to show in HA so I can turn off light groups (Living Room, Hall, etc)
You should have a look at the documentation for grouping entities here: https://home-assistant.io/components/group/
You can make your own Groups and Views (= Tabs) there.
For example my groups.yaml looks like this:
Thanks for the feedback, I’ve done some changes to the config to match yours with the groups, plus it helped to read up on groups, so shame on me for not doing that earlier.
