Whenever Home Assistant restarts, IKEA lights turn on at 0% brightness, regardless of what their previous value was.
Turn light ON at 70%
Turn light OFF
Restart Home Assistant
Turn light ON
Light is now ON at 0% (very dim)
I’m using the Home Assistant container, 2022.4.7
Please help!
Hedda
(Hedda)
April 26, 2022, 1:09pm
2
Did you try re-pairing the device with ZHA?
Recommend upgrading firmware on your Zigbee Coordinator regardless as well, just to try to rule that out.
If still have the same issue then suggest report to → https://github.com/home-assistant/core/issues
See https://www.home-assistant.io/integrations/zha#reporting-issues
and https://www.home-assistant.io/integrations/zha#debug-logging
There is also new diagnostic information that you can get from the ZHA integration, this can be acquired by clicking on the “Download Diagnostics” button in the device settings.
