Hi
I’m a new user to HA and I’m running FreeNAS 11.0 where I recently installed HA on to a new jail using this guide:
https://www.reddit.com/r/homeassistant/comments/6iahvj/guide_home_assistant_on_freenas/
I’m trying to setup the IKEA Tradfri component using the instructions on the component page:
Everything goes well until I enter the following command:
./configure --disable-documentation --disable-shared --without-debug CFLAGS=“-D COAP_DEBUG_FD=stderr”
In Putty I get a couple of warnings
checking for ctags... /usr/bin/ctags configure: ==> Note: your ctags does not support '--c-kinds'! configure: ==> Most likely, you are using the GNU Emacs ctag and not exuberant c tag configure: WARNING: ==> This option is required for target 'update-map-file' configure: WARNING: ==> which is not a problem if you just want to build the library libcoap.
and
checking operating system... configure: WARNING: ==> Currently unsupported operating system amd64-unknown-freebsd11.0! configure: error: ==> If you can provide patches to support your operating system please write to '[email protected]'.
If I then run
make
I get the following
make: no target to make.
make: stopped in /libcoap
I checked the /libcoap directory in the jail and I have Makefile.am, Makefile.in and Makefile.libcoap but no Makefile (no extension) which, I believe, is what I need in order to successfully run the make command.
I can also see the IKEA Tradfri configure button on the HA Home page but when it I enter the passkey at the prompt, the prompt remains without any errors and nothing happens. I’m assuming I need to complete the make commands above.
Can anyone help with how to get around this?
Cheers.
