Ikea Tradfri Remotes Strange behaviour in Automations, Zigbee2mqtt error
Dear Forum,
I am having some trouble with an automation, which I cannot wrap my head around :wink:
What works:
  • I have two Ikea tradfri remotes, that are fully working (If I look in “devices” I can see the remotes, if I press the buttons, HA shows me that the button was pressed)
  • I have an automation, that, whenever the toggle button on one of the remotes is pressed, the light in a room is toggled.This works for remote No 1 flawlessly. If I do not use the toggle button on remote No2 but another button, I can also toggle the light in this automation.
What does not work:
  • The toggle button of remote No. 2, although HA registers the click and all, does not trigger the automation
I am highly confused, any ideas?
Cheers,
CeeCee
Really? You want us to guess what your failing automation looks like?
Well, the automation works flawless with remote 1. The trigger part of remote 1 shows a “triggered” info when I press the button and everything is well. the trigger part of remote 2 is exactly configured as for remote 1, but does not show the “triggered” info if the button is pressed.
If I look at the “devices” both remotes behave the same, when I press the button on remote 1 or 2, HA registers the button click.
Here is the automation yaml code:
alias: OG_MA_Licht per Fernbedienung
description: ''
  - platform: device
    domain: mqtt
    device_id: 443955ada8784f0a87447fb4fd53c314
    type: action
    subtype: toggle
    discovery_id: 0x90fd9ffffe88acc1 action_toggle
  - platform: state
    entity_id:
      - switch.og_ma_sekschalter
  - platform: device
    domain: mqtt
    device_id: 18893aebb7114da4a73b32826217721f
    type: action
    subtype: toggle
    discovery_id: 0x90fd9ffffe526f7b action_toggle
condition: []
  - service: light.toggle
    data: {}
      entity_id:
        - light.og_ma_tuerseite
        - light.og_ma_leselampe
        - light.og_ma_fensterseite
mode: single
Did you create the automation using the GUI?
Yes, just found that sharing the yaml is easier than screenshotting the automation.
So I solved the problem. It was not the automation, but the Zigbee2mqtt addon. I renamed the remote2 in there and suddenly everything worked as expected.
