I’m really not sure where to start with this but it seems others are having this problem in other setups as well… I have 4 of these shortcut buttons around the house and, when they’re working, they work flawlessly, but it seems after some number of hours they stop (as though in a sleep mode) and require several presses (as many as 4) before they start to work again. I’ve pulled up the logs in Zigbee2MQTT and observed that, in this state, they are not reporting the button press to the network. Once they do show something in the logs, the automation fires and everything is back to normal.
Does anyone have a suggestion as to how I can improve this behavior? Is there a setting I can change that will change this, perhaps at the expense of battery life?
