Thank you. I got error message before when tying to connect with 2 O’s in the password so I thought I couldn´t use O in the password. After you answer, I tried again an now it works!
Maybe you have some errors in the password??
I used the code coming from the QR picture and it is exactly the same as the one I entered before.
Nothing works.
Did U try Brians way?
Yes, as stated in previous comment.
Use the code on the right side of the decimal point. That worked for me.
Sander
Just wanted to say thank you. As someone who is running HA Core and only has IKEA lights I was a frustrated I couldn’t get it to work. Your tip made it work. What puzzles me is why details like this aren’t on a dedicated HA community Tradfi wiki.
Half a year later I had re-installed my HA and ran into the same problem… Googling internet and stumbled upon this thread where I put in an answer, which worked also this time
For future reference, the string gotten when scanning the QR-code looks something like this
aa-bb-af-2b-ee-4f,RanDom1LettER
I copied the RanDom1LettER into the windows asking for the security code… baam! Worked like a charm, 6 monts later on the latest HA-version 2021.1
Br
Doesn’t work with the code or with the mac address. I hate this shit.
Hi All,
I am trying to add the IKEA DIRIGERA (Tradfri) hub into HA 2023.2.5. Thanks to the community here, I was able to determine that HOST = IP Address of the Hub. Then this thread suggests to use the second half of the large QR Code which looks a bit like this: f0c8fd207b0b32df
But I keep getting the timeout error. Both the hub and HA are plugged in via an ethernet cable directly into the router, so speed should not be an issue. I was able to add the HUE hub, but really struggling with the IKEA hub, next to tackle will be the Aqara hub.
Any suggestions would be greatly appreciated.
Steve
Hi - I have the same issue as WindriderAU. Host IP verified (I can see it in “show dhcp leases” in my router and ping stops working when I unplug the Ethernet cable, so this is 100%).
And I use the 16-digit hexadecimal code, which you can read from the QR code, for security code.
But I still get the “Timeout validating the code.”
Any ideas?
(I have Home Assistant Core 2024.2.2 and IKEA Dirigera hub version 2.505.2)
@WindriderAU or @ptaipale - did you manage to solve the Dirigera integration? I got the same issue, “Timeout validating the code.” over and over again.
The Tradfri hub is not the same as the Dirigera hub. Tradfri is one integration, Digidera does not work with it.
