Hi all,
I am using an ikea Trafdri Motion Sensor (latest model) home assistant core + Zigbee2MQTT + nodered with a conbee ii stick.
In nodered I can put in an mqtt node and see messages from the motion sensor.
In home assistant I can also see a binary sensor for the motion device.
I have a few issues at present:
When using the binary sensor (via the event state node in node red) I can see that the sensor turns “on” when motion is detected. However, after 2 minutes my light turns off and then a few seconds later comes back on again. It looks like the sensor fires a message to say there is no more motion. What is weird is that the even state node fires out both and on and off in rapid succession.
The binary sensor says it is active for a long while. When I watch the mqtt traffic, I can see the IKEA sensor is back in action after 90 seconds. This means I can’t prolong the time the lights are on for if people are in front of the sensor. Is there a way to alter the timeout for the binary sensor? The devices were automatically setup by Zigbee2MQTT so I’m not sure where to edit.
The sensor randomly fires events e.g.:
{"linkquality":81,"occupancy":false,"requested_brightness_level":254,"requested_brightness_percent":100,"update":{"state":"idle"},"update_available":false}"
and to this, the sensor in home assistant responds with:
{"topic":"binary_sensor.motion1_occupancy","payload":"on","data":{"entity_id":"binary_sensor.motion1_occupancy","old_state":{"entity_id":"binary_sensor.motion1_occupancy","state":"on","attributes":{"linkquality":81,"occupancy":true,"requested_brightness_level":254,"requested_brightness_percent":100,"update":{"state":"idle"},"update_available":false,"friendly_name":"motion1_occupancy","device_class":"motion"},"last_changed":"2020-12-23T20:30:54.866393+00:00","last_updated":"2020-12-23T20:30:54.866393+00:00","context":{"id":"a76152ee3df3e6fa4c6c789928c9370b","parent_id":null,"user_id":null},"original_state":"on"},"new_state":{"entity_id":"binary_sensor.motion1_occupancy","state":"on","attributes":{"linkquality":81,"occupancy":false,"requested_brightness_level":254,"requested_brightness_percent":100,"update":{"state":"idle"},"update_available":false,"friendly_name":"motion1_occupancy","device_class":"motion"},"last_changed":"2020-12-23T20:30:54.866393+00:00","last_updated":"2020-12-23T20:37:20.393108+00:00","context":{"id":"97496529168df288cbe3c7547a232642","parent_id":null,"user_id":null},"original_state":"on","timeSinceChangedMs":385656}},"_msgid":"22a9b020.cf6cf"}
Would appreciate your thoughts and guidance. Thanks,
C
