I bought an IKEA air quality monitor that can connect to Zigbee.
Pairing not successful so far. Have any of you tried on your end?
Did you Press the pairing button 4 times quickly? It will reset the device and pairing with ha.
Hi Sebski78.
thanks for your support
i move from Home Assistant Zigbee internal support to Zigbee2MQTT integration. i just integrate the Vindtyrka with this tip and it works fine.
When i first tried using Home Assistant Zigbee internal support, i do not press the pairing button 4 times. so i cannot confirm if it works or not on Home Assistant Zigbee internal support.
Thanks for your help
