GitHub Gist link
https://gist.github.com/russellhq/6971025c0c898603d5031691e7169593
Description
Use this Blueprint to factory reset your IKEA Zigbee bulbs when you have them connected to a smart switch. This can be helpful if you are having trouble resetting your bulbs, are troubleshooting and need to reset a number of times or are swapping/resetting your hub and need to repair your bulbs.
Blueprint YAML Code
blueprint:
name: IKEA Bulb Factory Reset
description: Factory resets IKEA bulbs for re-pairing with a ZigBee Hub
domain: automation
input:
input_boolean:
description: This Input boolean will trigger the factory reset automation
selector:
entity:
domain: input_boolean
light_switch:
description: The light switch to use for factory resetting the IKEA bulb
selector:
entity:
domain: switch
- entity_id: !input input_boolean
platform: state
to: 'on'
- service: switch.turn_on
entity_id: !input light_switch
- delay: '2'
- repeat:
count: '6'
sequence:
- service: switch.turn_off
- delay: '1'
- delay: '1'
- service: input_boolean.turn_off
