Seems to be missing SPI info and I’m not sure what the config for that is as I get this error when compiling: Component display.ili9341 requires component spi.
Can someone pls share their code/pins to get this running.
Tried it on ESP32 as well and with your pins above I get the hello world to work ok however
as soon as I enable the esphome BT proxy it stops working, seeing this in the logs:
It doesn’t matter, you need 7 GPIO pins and select the right ones on the 8266.
I recommend using esp32 as many problems are reported with 8266.
I have several 2.8" to 3.2" on esp32 and they all work without issue
