Ili9488 + Esp32 -S3
I have ili9488 display without touch, esp32-s3. Screen powered by 5V, signal lines via 3.3V. The image is displayed well, the colors are also well reproduced. However, after a second there are jumps, colors diverge, the content jumps, the image is illegible, stops. You can see it in the foto.
Connection diagram for ESP.
Cs-10; dc-7; rst-4; LED-13; mosi-11; sclk-12; with miso connected and as without, no improvement.
Program written on esphome, I want to use it for Home Assistant.
The most interesting thing is that when I hold the mass of the system with my finger, the screen works and no other errors pop up on logs.
Code:
esphome:
  friendly_name: esp32-s3-lcd
#  platformio_options:
   #board_build.psram: true
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Example configuration entry
psram:
  mode: quad
  speed: 80MHz
# Enable logging
logger:
  logs:
    component: ERROR
# Enable Home Assistant API
api:
  encryption:
    key: "IYNl+zcOfH1/cf5SbWwyBjAO2BMguYtIISgmI3K7Wq4="
ota:
  - platform: esphome
    password: "f91ab4cda59e8753c7f0644ce1c3cb63"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-S3-Lcd Fallback Hotspot"
    password: "okDaEXJHF6H3"
time:
  - platform: homeassistant
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      inverted: true
      mode:
        input: True
        pullup: False
    device_class: power
    entity_id: sensor.atc_temperaturesebo
    internal: true
    entity_id: sensor.atc_humiditysebo
    internal: true
    entity_id: sensor.roznicowa_phase_a_power
    internal: true
    entity_id: switch.gniazdo_pc_1
    internal: true
    entity_id: sensor.czujnik_hdd
    internal: true
# Define a PWM output on the ESP32
output:
  - platform: ledc
    pin: GPIO13
# Define a monochromatic, dimmable light for the backlight
light:
  - platform: monochromatic
    output: backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
spi:
  clk_pin: GPIO12
  mosi_pin: GPIO11
  miso_pin: GPIO9  # Niektóre modele mogą wymagać MISO, choć często jest nieużywane
display:
  - platform: ili9xxx
    model: ILI9488
    dc_pin: GPIO07
    reset_pin: GPIO4
    update_interval: 500ms  # Aktualizuj co 2 sekundy
    data_rate: 20MHz
    invert_colors: false
    show_test_card: false
    rotation: 90
    dimensions:
     height: 480
     width: 320
    pages:
      - id: page1
        lambda: |-
         it.fill(Color(0, 50, 100));
         it.strftime(100, 80, id(font3), id(my_white), "%H:%M:%S", id(esptime).now());
         it.strftime(40, 180, id(font3), id(my_white), "%d-%m-%Y", id(esptime).now());
      - id: page2
        lambda: |-
         it.fill(Color(0, 0, 150));
         // Print time in HH:MM format
         it.strftime(0, 0, id(font3), "%H:%M:%S  %d-%m-%Y", id(esptime).now());
         it.print(0, 60, id(font1), id(my_white), "Temperatura tutaj:");       if (id(Temp_u_Seby).has_state()) {       it.printf(180, 60, id(font1), "%.1f C", id(Temp_u_Seby).state);        }
         it.print(0, 80, id(font1), id(my_white), "Wilgotnosc tutaj:");        if (id(Wilg_u_Seby).has_state()) {       it.printf(180, 80, id(font1), id(my_white), "%.1f %", id(Wilg_u_Seby).state);    }
         it.print(0,100, id(font1), id(my_white), "Jest dzis:");           it.strftime(100,100, id(font1), "%A a miesiac: %B", id(esptime).now());
         if (id(Gniazdo).has_state()) {       it.filled_circle(440, 180, 30, Color(0, 255, 0));} // kolor zielony
         if (id(HDD).has_state()) {it.filled_circle(440, 260, 30, Color(255, 0, 0));} // kolor czerwony
         it.print(0, 120, id(font1), id(my_white), "Zuzyta Moc tutaj:");  if (id(MOC_u_Seby).has_state()){it.printf(180,120,id(font1), id(my_white), "%.1f W", id(MOC_u_Seby).state);} // moc seba
#it.print(100, 200, id(font1), id(my_white), "LCD u Seby");
color:
  - id: my_red
    red: 100%
    green: 3%
    blue: 5%
  - id: my_green
    red: 0%
    green: 100%
    blue: 5%
  - id: my_blue
    red: 0%
    green: 3%
    blue: 100%
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
font:
  - file: "fonts/Roboto-Regular.ttf"
  - file: "fonts/fontseba.ttf"
captive_portal:
Mass of the system?
Yes, the screen ground or the esp32 ground. When I put my finger on it, all the color jumps, content calm down and the image is fully visible. On another ESP 32 the situation is similar.
This is the second ili9488, on the previous one the same situation, the screen ground and ESP and the power supply are connected. I added filtering capacitors on the power supply, at the ili9488 pin output itself, but no effect.
Possibly a bad solder joint?
Or not solder at all…
The connections are in good condition and checked.
Try lowering the display data rate. Looks like you have long wires.
Data transmission was 20 MHz changed to 40 MHz unattended
From the pic it looks like you have an electrolytic capacitor connected from GND to CS. What is that for? Also you said in the first post you are powering the screen from 5V, but the pic shows otherwise.
Anyway, if touching the device changes its behaviour, it’s definitely an electrical issue - bad connections, bad power, bad ground or something like that.
The capacitor is on the screen power supply. And I had 5v on the power supply, then I soldered it to 3.3v, taking into account the jumper j1, still no effect.
What power supply/supplies you have? Did you try with others?
Tiny ceramic caps here and there might be worth to try.
