I’m stuck, and could really use your help…
I also don’t know if this is an adapter install / config issue, device issue, user issue (most likely), or what.
- I’m running HA on a Win 10 VM.
- I’m using a - GoControl CECOMINOD016164 HUSBZB-1 USB Hub
- I installed the Win 10 Drivers, got it setup in HA w/
zwave:
usb_path: /dev/ttyUSB0
network_key: "0x2e, 0xcc, 0xab, 0x1c, 0xa3, 0x7f, 0x0e, 0xb5, 0x70, 0x71, 0x2d, 0x98, 0x25, 0x43, <redacted>, <redacted>"
zha:
usb_path: /dev/ttyUSB1
database_path: /config/zigbee.db
Within in Configuration > ZHA > Silicon Labs EZSP > I have…
Silicon Labs EZSP
EZSP
by Silicon Labs
IEEE:
00:0d:6f:00:<redacted>
Nwk:
0x0000
Device Type:
Coordinator
LQI:
255
RSSI:
Unknown
Last Seen:
2020-03-19T21:18:07
Power Source:
Mains
Quirk:
bellows.zigbee.application.EZSPCoordinator
When I click on “Add Devices” under ZHA, it spins indicating it’s looking for the device to add. I then plug in this (left over from Xfinity Home) smart plug w/ the side button held down, and get nothing. I’m plugging this in within about 5 ft of the USB adapter.
The device (which is confirmed to work w/ HA and ZHA in other threads) is a CentraLite 4257050 RZHAC smart plug.
My issue, is that I quite literally have no idea what I’m doing and am stumbling through this. 2 hours ago, I simply thought I’d plug the USB into my Win10 box, and the VM would see it - followed by HA “Detecting” it automatically, and I’d be good to go. Clearly, that’s not the case, and I’ve made it this far.
Being that I don’t know what I’m doing - I don’t know if I configured this incorrectly (my logs aren’t showing any errors), or I’m doing something else incorrectly. With multiple failure points possible, I don’t really know how to test next.
Can anyone help point me in the right direction? I feel like I’m in over my head at this point…
