dump, i just checked logs: says at the end (last line), cant create network, too much interference…
Logger: aiohttp.server
Quelle: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
Erstmals aufgetreten: 20:59:32 (1 Vorkommnisse)
Zuletzt protokolliert: 20:59:32
Error handling request
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1114, in request_callback_rsp
return await callback_rsp
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 264, in start_network
commissioning_rsp = await self.request_callback_rsp(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1111, in request_callback_rsp
async with async_timeout.timeout(timeout):
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 141, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 228, in _do_exit
raise asyncio.TimeoutError
TimeoutError
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 567, in _handle
return await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 410, in _async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 388, in async_step_form_initial_network
return await self.async_step_form_new_network(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 394, in async_step_form_new_network
await self._radio_mgr.async_form_network()
File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 277, in async_form_network
await app.form_network()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 351, in form_network
await self.form_network(fast=True)
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 404, in form_network
await self.backups.restore_backup(
File "/usr/local/lib/python3.12/site-packages/zigpy/backups.py", line 171, in restore_backup
await self.app.write_network_info(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 171, in write_network_info
await self._znp.write_network_info(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 400, in write_network_info
await self.start_network()
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 302, in start_network
raise zigpy.exceptions.FormationFailure(
zigpy.exceptions.FormationFailure: Network formation refused: there is too much RF interference. Make sure your coordinator is on a USB 2.0 extension cable and away from any sources of interference, like USB 3.0 ports, SSDs, 2.4GHz routers, motherboards, etc.
all of the named stuff is right next to the hp pro liant micro… and I probably wont have a usb extension handy…
edit: found an extention from logitech for the unified keyboards/mous dongles, that did work, surprisingly as ist several years old…
now lets see.
