I’m new to HA so please bare with be. I’m trying to add the Environment Canada Weather sensors to my setup. I added the following to my configuration.yaml but no luck. I’m on HassOS 3.7
I see in the setup notes that I’m supposed to run “sudo apt-get install libatlas-base-dev libopenjp2-7” . I have the SSH addon but when I ssh and try this command I get “command not found” I also tried “apt-get install libatlas-base-dev libopenjp2-7” and also get “command not found”
Hi @richard2, welcome to Home Assistant from another fellow Canadian. Are you following the integration instructions here? I don’t see any mention of having to run any commands.
Also not sure if it’s just a typo but for your station you have AB(Alberta) but your station ID is listed as QC(Quebec).
Hey @richard2, to follow up on what Petro said, as you’re running HassOS you won’t be able to run that command as HassOS isn’t a standard linux distribution however this shouldn’t be needed when running HassOS.
Do you have any errors related to Environment Canada in your home assistant logs?
I also recommend ensuring your station id is correct. As Northcountry mentioned the station id in your message has AB as the province but the station id is in QC.
