I just created a new dashboard I am going to design and use for mobile displays.
It’s currently UI controlled so why are there non-existent entities on it?
The only thing I can think of is that sometimes the cards seem to fill in a few values for you, I assume by way of example.
I understand the autofill aspect as that is what I used in Overview when I first started before I took control of it and started massaging it. The entities in this new UI controller dashboard do not exist so that is what is puzzling me…
Yeah come to think of it, if they aren’t even existing on your system, heaven knows where they come from?
You might have played around with addons and integrations that have added the entities and then you have not removed them when you removed the addons and integrations.
Settings → Devices & Services → Entities
Sort on the column named Status.
The error entities will usually have a red icon in that column.
Figured it out…
In group.yaml
I had an internet:
group with those three sensors listed which I had deleted.
In packages/open_garage.yaml at the very end of it I had another group garage:
which contained a sensor that I had afterwards renamed further up in the file…
