Hi all,
often google home replies : “I’m sorry I can’t access to home assistant at the moment”… If I wait some minutes and I repeat again the command probably it works…
I have Home Assistant 2021.6.4 installed on raspberry pi3b.
Connectivity between Google and your HA, obviously
If HA takes too long to “acknowledge” the command, e.g. long running script. For whatever reason, it seems HA waits for the end of the execution of the action before acknowledging Google
If anyone else is googling the problem: I strongly recommend enabling local fulfillment for Google Assistant. This will substantially lower the fulfillment failure rates especially if you are using DuckDNS for your remote HA access. As a bonus, the fulfillment latency will also decrease. The default is cloud fulfillment accessing HA via your dynamic DNS solution.
