I’m trying to use the above board. I copied the details from “the list” but that did not work. Any suggestions?
my code snippet is
esp32:
platform: espressif32
board: esp32doit-devkit-v1
my code snippet is
esp32:
What are you trying to do with it?
The code you show does nothing…
Maybe start with
thanks for the reply. here is my total code
esphome:
friendly_name: 32 soil moisture
esp32:
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xSPemlHe3fu4SxFAh8y9EPSF7uc/xSsj46xUhov9O04="
ota:
- platform: esphome
password: "c1b89da70746de31040566e3a5a0053c"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "32-Soil-Moisture"
password: "59pb65v8DhDS"
captive_portal:
- platform: adc
name: "Soil Moisture Voltage"
pin: GPIO36
type or paste code here
I have a few esp32doit-devkit-v1 on my network and the following works for me:
esp32:
framework:
type: arduino
big THANKS. My sketch seems to pass ok. Odd how coping cont and pasting seems to alter the spacing etc. Bloody YAML
How did you find how to link esp to esphome as I could find an instruction that worked. Also have you found a way to OTA upload without having to press the boot button om the ESP32? Any further help will be appreciates and will reduce my frustration
In fact it should work without boot button. Do you have anything else connected to your esp GPIOs (other than GPIO36)?
no nothing elso
Hi there, strange, i dont have to press the boot button at all to do OTA, even if you use a USB cable to run the flash onto the board it should do so without the need to press the boot button.
Make sure you have the following in your OTA section in your yaml file.
esphome:
friendly_name: Lounge
comment: Temperature and Humidity
esp32:
framework:
type: arduino
logger:
api:
encryption:
key: !secret api_key
ota:
- platform: esphome
password: !secret ota_password
wifi:
ops I had another go and did not need to press the boot button. i think you guys have unjinked my board. Thank you
