I’ve been trying to get this working, searched around a lot but doesn’t seem to want to work for me.
I’ve uploaded .png’s to the www folder and referenced them as /local/image.png under the icon section of entities or whatever other style card. Only one that I’ve seen work is a picture entity however this is what I am attempting to achieve:
![image](https://community-assets.home-assistant.io/original/4X/e/b/c/ebcf542e98ac7803388b8d146c75d2cecc37b6db.png)
You either have to change your configuration.yaml or better your customization.yaml.
switch.wemo_switch_1:
friendly_name: Toaster
entity_picture: /local/toaster.jpg
Have a look here:
Thanks for the reply,
I see, I saw that earlier however I didn’t read enough after seeing this on my entity:
This entity (‘sensor.sonarr_online’) does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail.
So in my configuration.yaml I now have:
- platform: command_line
entity_picture: /local/sonarr.png
icon: /local/sonarr.png
Perhaps I need to reboot or something as I don’t see the image?
