Image_upload - libtiff.so.6: cannot open shared object file
Hello there,
If you have, like me, an error with 2023.10.0 like this on RPi (because latest version on bullseye is 5.6)
Component error: image_upload - libtiff.so.6: cannot open shared object file: No such file or directory
Here is “my” solution
  1. Open a command line
  2. Clone the libtiff source code
    sudo apt update
    sudo apt upgrade
    sudo apt install git
    git clone https://gitlab.com/libtiff/libtiff.git
  3. Install cmake (optional if you have it already)
    sudo apt install cmake
  4. Make and install
    cd libtiff
    cmake .
    make
    make test
    sudo make install
  5. Create symlinks
    cd /usr/lib/arm-linux-gnueabihf/
    sudo ln -fs /usr/local/lib/arm-linux-gnueabihf/libtiff.so.6 .
    sudo ln -fs /usr/local/lib/arm-linux-gnueabihf/libtiff.so.6.0.2 .
Thanks! Finally back into my HA build. Looks like i will have to get onto HA-OS, seems like they are not keeping us core users are being left behind.
We are an endangered species
Hero - thanks for writing this out! :smiley:
I’ve been trying to fix this for hours!
Your fix is the only thing that got it working.
Thank you so much for publishing this
