jmyler12
(Justin Myler )
April 20, 2023, 6:29pm
1
I have had an IMAP email content sensor set up for about a year now and has been working well until recently. I believe it to have been 2023.3 that broke it, or at least was around that time that something changed.
Every morning when the school bus arrives and email is sent out and alerts my kid that he needs to head to the bus stop, I delete the email and it resets for hte next iteration. Recently though deleting the email doesn’t reset the sensor.
Is anyone else experiencing the same?
When I restart home assistant it will reset the sensor because there is no email in the inbox and when it does appear in the mornings it will trigger the automation correctly, but I certainly don’t want to have to restart home assistant every day to fix it.
Looks like this integration will be deprecated in the next releases.
home-assistant:dev
← jbouwh:deprecate-imap_email_content
opened 09:46PM - 28 Mar 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Deprecate the `imap_email_content_integrations`. The IMAP server config can be migrated to the `imap` integration with a repair flow. A `yaml` configuration is generated to set up a template sensor and is shown in the flow to allow the user to copy and past the config into `configuration.yaml`.
Base on the original configuration:
```yaml
- platform: imap_email_content
server: imap.example.com
port: 993
username: [email protected]
password: LdH0@gv!
folder: INBOX.Notification
value_template: "{{ subject }}"
The repair flow will look like:
![afbeelding](https://user-images.githubusercontent.com/7188918/228658107-56f1719b-8a4e-4c2c-a965-65f95ad7035b.png)
The next step:
![afbeelding](https://user-images.githubusercontent.com/7188918/228661245-a22be718-4c4d-4db3-a734-65931e30fadd.png)
If the IMAP config is migrated but the user has not removed the `imap_email_content` configuration from `configuration.yaml` the next time Home Assistant is started, then a non fixable issue is created.
With that warning again is shown how to setup a template sensor with together with the `imap` config entry.
![afbeelding](https://user-images.githubusercontent.com/7188918/228661483-a6fe8a88-3dea-4df6-980b-de3af403d954.png)
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [x] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/26792
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [x] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
jmyler12
(Justin Myler )
April 20, 2023, 8:07pm
3
ooo lovely! Thanks for the link.
Does the imap integration work with yahoo email accounts? I have tried inputting my credentials during setup ,but it randomly says it failed on email, password, and search fields input.
