I have installed the IMAP integration and created a sensor that seems to be working properly. I created an automation that uses the state change as a trigger, so I know its updating.
Using DeveloperTools|States, I can see that it has the following data:
state: 2
state_class: measurement
unit_of_measurement: messages
friendly_name: Email for Webmaster
The following template creates the entity “sensor.aa_imap_content”, but its only attribute is FriendlyName. NO other
The template is almost identical to that in the IMAP examples. Is there any direct method to observe trigger.event.data?
What am I missing?
Thanks.
- trigger:
- trigger: event
event_type: "imap_content"
- name: AA_imap_content
state: "{{ trigger.event.data['subject'] }}"
attributes:
Entry: "{{ trigger.event.data['entry_id'] }}"
UID: "{{ trigger.event.data['uid'] }}"
Message: "{{ trigger.event.data['text'] }}"
Server: "{{ trigger.event.data['server'] }}"
Username: "{{ trigger.event.data['username'] }}"
Search: "{{ trigger.event.data['search'] }}"
Folder: "{{ trigger.event.data['folder'] }}"
Sender: "{{ trigger.event.data['sender'] }}"
Date: "{{ trigger.event.data['date'] }}"
Subject: "{{ trigger.event.data['subject'] }}"
Initial: "{{ trigger.event.data['initial'] }}"
To: "{{ trigger.event.data['headers'].get('Delivered-To', ['n/a'])[0] }}"
Return-Path: "{{ trigger.event.data['headers'].get('Return-Path',['n/a'])[0] }}"
Received-first: "{{ trigger.event.data['headers'].get('Received',['n/a'])[0] }}"
Received-last: "{{ trigger.event.data['headers'].get('Received',['n/a'])[-1] }}"
