I want to set up an IMAP trigger on the sent to address rather than on the sender’s address of an email. More specifically, I am sending myself an email with the + suffix so I can differentiate specific emails. In configuration.yaml I have the folllowing but it never triggers although it triggers without the +suffix (but of course that then gets overwhelmed by all my other emails). Is it something that could work or am I trying the impossible?
template:
- trigger:
- platform: event
event_type: "imap_content"
event_data:
sender: "[email protected]"
- platform: event
event_data:
To: "[email protected]"
- name: received_email
state: >-
{% if 'text I want' in trigger.event.data["subject"] %}
Free
{% endif %}
attributes:
subject: >-
{{ trigger.event.data["subject"] }}
{% endif %}
To is not a valid variable for event data, and username won’t show the +suffix. You’ll need to filter in a template and alter your state and attribute templates to cover for trigger events that don’t meet all your criteria.
template:
- trigger:
- platform: event
event_data:
- platform: event
event_data:
username: "[email protected]"
- variables:
to_suffix: "{{ '[email protected]' | lower in trigger.event.data['headers'].get('Delivered-To') | map('lower') | list }}"
allowed: "{{ to_suffix or (trigger.id == 'event1') }}"
state: >-
{% if allowed and 'text I want' in trigger.event.data["subject"] %}
Free
{% else %}
Not Free
{% endif %}
attributes:
subject: >-
{% else %}
{{ this.attributes.subject | default('No subject', 1) }}
{% endif %}
Thanks. Where did you find that out? I’ve never seen the action: statement.
As it happens I’ve found an alternative approach as I can do the myself+suffix approach for the sender (I discovered gmail allows you to create multiple such senders).
It was added in the past 8 month (I don’t remember which release exactly) to enable creating sensors that incorporate response data from service calls like weather.get_forecasts and calendar.get_events.
