I’ve had 2xIMOU cameras and I use ONVIF integration for streaming and motion detection. But with the recent home assistant update, the motion detection has stopped working. Has anyone experienced the same issue? I understand that there is a custom IMOU Cameras integration but that hasn’t served well for me so I would like to stick to ONVIF integration.
Hi. I am having this issue also. Using ONVIF integration with Wansview cams.
Motion detection sensor gets 'stuck every few hours.
Performing a ‘reload’ operation restores functionality.
I am new to HA and added cameras in 12/2022.
Thanks!
The same issue for me with IMOU cam using onvif, but only on some models, the new ones.
On new products IMOU remove web access to cam. On these products motion sensor works in HA for 2 or 3 days and then stops. I cannot remember if the issue start after an HA upgrade. The old cams with web access still works.
Thanks to anyone who can help!
Someone? Anyone? None of the motion sensors are working in home assistant either in ONVIF or in IMOU integrations, hence making the integration bit pointless
if I set port 8123 with letsencrypt (https) certificate, the motion sensor stops working. The same doesn’t work if I leave HA http but close the port with iptables and access from a reverse proxy from another port.
it appears to make a request to http://…8123
If I delete the onvif device and recreate it, the sensor disappears.
