Is there a possibility to use the imou life integration to use the imou vaccuum cleaner in home assistant?
I tried to use this integraion a while before, but didn’t get the possibility to integrate the vaccuum cleaner.
Thanks Klaus
Hi Klaus,
Currently, the Imou Life integration for Home Assistant primarily supports cameras and related devices, but it doesn’t natively support Imou vacuum cleaners. However, some users have found workarounds by using the Google Assistant SDK integration, which exposes devices in Google Home to Home Assistant. This method allows you to start and stop the vacuum cleaner via Home Assistant.
If you’re comfortable with a bit of setup, this could be a viable solution for you. Let me know if you need more details on how to set this up!
Best Regards,
UPSers com
Thank yo for your reply, I’ll try this
Hello, I’m a bit of a beginner even if I’m starting to understand certain things, I’d like a little more detail on how to implement the control of my Imou vacuum cleaner on my Home Assistant via a Google Assistant SDK integration.
Thanks in advance!
