Hi…I congratulate you for the excellent work done with this integration. I purchased a cam cruiser 2
IPC-GS7E-3M0WE
da Imou
Firmware: 2.800.0000000.5.R.230511
Hardware: 9F0969CPAZ6EEC8
and there seems to be no head detection switch. Active motion detection with smart tracking but there is no movement on the camera.
Imou Life: PTZ Location service seems not to work while I am successfully using service: imou_life.ptz_move
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:468
First occurred: 09:29:54 (1 occurrences)
Last logged: 09:29:54
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 40999: Unknown error.
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2067, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2104, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 833, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 878, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 948, in _handle_entity_call
result = await task
File "/config/custom_components/imou_life/camera.py", line 117, in async_service_ptz_location
await self.sensor_instance.async_service_ptz_location(
File "/usr/local/lib/python3.11/site-packages/imouapi/device_entity.py", line 703, in async_service_ptz_location
return await self.api_client.async_api_controlLocationPTZ(
File "/usr/local/lib/python3.11/site-packages/imouapi/api.py", line 520, in async_api_controlLocationPTZ
return await self._async_call_api(api, payload)
File "/usr/local/lib/python3.11/site-packages/imouapi/api.py", line 227, in _async_call_api
raise APIError(error_message)
imouapi.exceptions.APIError: 40999: Unknown error.
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/imou_life/camera.py:117
Integration: Home Assistant WebSocket API (documentation, issues)
[140480848535744] Error handling message: Unknown error (unknown_error) stefano from 192.168.1.208 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 782, in handle_execute_script
script_result = await script_obj.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1578, in async_run
return await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
raise exception
result = await task
Thanks for your help
Stefano
