Awesome!
For now the only thing I could accive is to write out the transitions, but failed to call it directly like the fire flicker - tried it with flow, custom_effects, transitions, effects_config, effect/s. Or is’nt it thourght to work this way?
The fire Flickr is already pre recreated from the docks.
Service and entety is clear. But I don’t come on the data I have to pass to activate the pre defined Flow.
There is an example in the docs of how to re-create the candle flicker, yes, but you can’t call a service to activate it as a pre-defined flow as far as I am aware. That’s the point of the new custom_effects transitions. So if you want the candle flicker, simple re-create that effect using transitions exactly as is shown in the docs
Sorry, I had gone off on a tangent You should be able to select the newly added custom_effect for a light like you do for the other effects. Is your Fire Flicker showing up in the drop-down list when a light is on?
Aaaah! There youre hidden! Thanks so much - Tryed effect, But in the wrong service. The docks doesnt point this out (yet)
Also a nope on the dropdown. Meight be because of the version of the bulb (ct2)
Technically the docs do day how to call the service for an effect, but I guess it’s not explicit that the custom_effects are called as per the standard ones.
Is it possible to define custom effects using automatic config for a light? Or do I have to do a manual config the light to use the custom_effects? The example here Yeelight - Home Assistant is for manual config.
I tried the following in configuration.yaml, but it’s not working:
I need turn on a light with police effect with a automation, but I want that if I turn on it manually be white, I think I need define a custom_effects like this:
