My current problem is probably quite simple. I would like to monitor the indoor air quality, using multiple sensors. I have the BME680 installed and would like to run a plantower particle matter sensor next to it, and in the future extend this to more/better sensors. I have trouble extending my current YAML code to include more than the BME680. My questions is, how do I extend the following yaml code to also include my particle matter sensor, which should be connected correctly (5V and GND work, fan is working) Pin 4 to D6 and pin 5 to D7. My current code to run the BME680 is:
esphome:
friendly_name: airquality
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "key"
ota:
wifi:
ssid: "ssid"
password: "password:"
ap:
ssid: "ssid:"
i2c:
sda: GPIO4
scl: GPIO5
bme680_bsec:
address: 0x77
- platform: bme680_bsec
temperature:
name: "BME680 Temperature"
pressure:
name: "BME680 Pressure"
humidity:
name: "BME680 Humidity"
iaq:
co2_equivalent:
name: "BME680 CO2 Equivalent"
breath_voc_equivalent:
name: "BME680 Breath VOC Equivalent"
#update_interval: 5s
# Example text sensor for air quality status
text_sensor:
iaq_accuracy:
name: "BME680 IAQ Accuracy"
