No, you cannot use the code as-is in ESPHome.
If you have experience in C++/Arduino, you can re-use the concept of the code in a ESPHome custom component, but requires development work / skills.
No worries let me know if you ever manage to get this into ESP Home!
In short, the main function I want is using the SD card in 1bit mode so I can free up other pins on the ESP32-CAM-MB.
The benefits are actually quite useful…
Makes use of the onboard SD Card
–Also uses 1-bit mode as described below. which frees up pins 12 & 13
SD card support (using 1-bit mode - gpio pins are usually 2, 4, 12 & 13 but using 1bit mode only uses pin 2) - I have heard there may be problems reading the sd card, I have only used it to write files myself?
Uses the flash when taking an image (and ability to disable this function)
Simple web interface (could be improved) but does the job
Enable live stream when required (so it doesn’t kill the board)
Ability to customise the LEDs / Brightness / on-off
This was my initial thought.
I have some experience with C++ but little with Arduino (and want to keep it that way - prefer ESPHome).
My initial thoughts (and I’m probably way off) - is that the code would just need altering slightly to not pull some libraries(?) but not 100% sure what needs editing from the GitHub file.
I think for now I’ll leave that standard software on (even thought I can’t get pin13 connected to a motion sensor!).
On a separate note, I’m also confused about the boards when using ESPHome.
For the above ESP32 CAM, I’m using this config but not sure on how to find a list of boards and the GPIOs.
