Hi, in a Esphome device I want to retrieve data from a sensor in HA (power sensor) but only when/if i want: so in this code:
- platform: homeassistant
entity_id: sensor.power
how could I insert a number component or binary sensor to “enable” that import or p.e. select another one? I think about using copy component but how filter using lambda? or better use an on_value automation to modify a variable with IF condition? THANKS
- platform: copy
source_id: power
name: "Copy only if i want"
filters: ........#pass data only if enabled is true#
switch:
entity_id: switch.enable
