Import DeConz/Phoscon Backup tu ZHA?
I am currently using Deconz/Phoscon under Windows with a Conbee2.
Is there any way to use ZHA directly with the Conbee2 without reconnecting all the devices?
So e.g. import the backup of DeConz/Phoscon into ZHA? I haven’t found anything on this yet.
Jens
I have a similar problem. My ConBee II seems to be dropping connections and devices become unavailable. The devices seem OK and there are lots of them so I was looking for a way to backup the ZigBee network (done) and the paired device lists. Then reload into a new (I’ve bought a SonOff ZigBee 3.0 dongle) dongle and use ZHA instead of DeConz.
I’ve worked out how to backup the Conbee II dongle using zigpy-cli but as Home Assistant is not running it does not include the paired devices information! Trying to do a backup with DeConz running fails. Is there a way to share the serial line over USB connection between DeConz and zigpy-cli? Or a way to extract the pairing data in a re-usable format from the DeConz data store whereveer that is located?
Any help appreciated,
Nick
