Hope the title makes some sense?!?!?!
So I have been using lovelace for quite some time now and have the option configured in the config to enable it’s use as .yaml
I now want to have a play with it using the GUI editing.
How do I copy my lovelace .yaml info across?
taddeuz
(Philip Taddey)
2
I would like to know that, too. Is there a file in which the lovelace config (edited in the frontend) is saved?
You open the GUI Editor (3 dots top right) then 3 dots again for raw editor then just cut/paste the YAML file and save.
markbajaj
(Mark Bajaj)
4
you can’t do that until you remove (or comment out) the
lovelace:
mode: yaml
from the configuration.yaml though.
Then just copy all the ui-lovelace.yaml file into the raw editor in the GUI. It will remove all comments though that you had in the ui-lovelace.yaml.
When I try to paste my code I get this error:
Your config is not valid: TypeError: Expected a value of type
[object] | undefinedfor
resourcesbut received
null.
Managed to solve this by removing resources:
This had nothing in it.
