Import/Sync Calendar Events
Hello all,
I would like to share my Blueprint with you.
With this Blueprint you can import/sync calendar events from one calendar to another.
For example you can import calendar events from your google calendar to another calendar.
Prerequisites
Have at least two calendar configured in Home Assistant. One calendar must have write access.
blueprint:
  name: Import Calendar Events
  description: "Imports calendar events from a source calendar to a destination calendar within a defined timeframe."
  domain: automation
  author: N1c093
  input:
    calendar_source:
      description: "Select the calendar from which events will be imported."
      selector:
        entity:
          domain:
            - calendar
    calendar_destination:
      description: "Select the destination calendar where the imported events will be saved."
      selector:
        entity:
          domain:
            - calendar
    timeframe:
      description: "Specify the time duration for which events should be imported (e.g. 2 days)."
      selector:
        duration:
          enable_day: true
    prefix:
      name: (optional) Event Prefix
      description: "Add a custom prefix to the title of imported events in the destination calendar, if desired."
      default: ""
      selector:
        text:
      description: "Choose when the automation should be triggered (e.g., time-based, event-based)."
      selector:
  source_url: https://community.home-assistant.io/t/import-sync-calendar-events/786301
mode: single
variables:
  calendar_source: !input calendar_source
  calendar_destination: !input calendar_destination
  prefix: !input prefix
trigger: !input trigger
  - data:
      duration: !input timeframe
      entity_id: "{{ calendar_source }}"
    response_variable: source_calendar_events
    action: calendar.get_events
  - repeat:
      count: '{{ source_calendar_events[calendar_source]["events"] | length }}'
      sequence:
        - response_variable: existingevents
            entity_id: "{{ calendar_destination }}"
            start_date_time: "{{ source_calendar_events[calendar_source].events[repeat.index-1].start }}"
            end_date_time: "{{ source_calendar_events[calendar_source].events[repeat.index-1].end }}"
        - variables:
            event_summary: "{{ source_calendar_events[calendar_source].events[repeat.index-1].summary }}"
            prefixed_summary: "{{ prefix }} {{ event_summary }}"
            existing_events: "{{ existingevents }}"
            existing_events_summary: >-
              {{ existingevents[calendar_destination].events |
              map(attribute='summary') | list }}
        - condition: template
          value_template: >-
            {{ not prefixed_summary in
        - target:
          data_template:
            summary: "{{ prefixed_summary }}"
            description: "{{ source_calendar_events[calendar_source].events[repeat.index-1].description }}"
            location: "{{ source_calendar_events[calendar_source].events[repeat.index-1].location }}"
          enabled: true
          action: calendar.create_event
        - delay: "00:00:01"
I hope you like my Blueprint. Please leave your feedback in the comments.
Hello @N1c093
Thanks for doing this, it seems to be just what I’m looking for but can I check if it should work exporting from a local calendar to a CalDAV calendar?
My remote CalDAV calendars have write access but I’ve never been able to create a new event in them from Home Assistant. That’s presumably going to stop this automation working as I’d like it to, but maybe there is a way to allow Home Assistant to write to an external CalDAV file?
Sorry if this is a bit off topic but it would be very useful to get this for me to work with CalDAV calendars. Happy to help test and troubleshoot.
