Imported nodes in nodered are not visible
Hi when trying to import flows via the import function it is shown that the nodes are imported but I cannot see them anywhere.
What am I doing wrong or missing.
Could not find it in the docs. Exporting my flies is working fine as well.
Thank you
This is the flow that I would like to change to my needs but it unfortuately does not work as desired.
https://flows.nodered.org/flow/97d1ad82740d1c0ca1e7d1936862969e
I copied the node and pasted it in my NodeRed via the import function but it does not show up in my flows, although it says that it imported 14 Nodes and 1 subflow bul I cannot see them anywhere. Any help
would be appreciated.
It would be under the subflow section.
unfortunatly I could not find it anyhere arround there either. It seems as if it is not visible but is imported anyway. However I am not able to change the import to my needs.
Ah it is on the other side. Great. Now I know what the guy is doing. And yet it seems that there is a much easier way to activate certain scenes using nodeRed, just like I am able to do in Automations.
So basically what I did in Automalions using .yaml I would like to achieve ine NodeRed
description:
alias: Dimmer Test 1 mit Natascha docken
description: ""
  - device_id: ca119d2e1fb7f499b297b05ba367cd5e
    domain: hue
    platform: device
    type: remote_button_short_release
    subtype: dim_up
condition:
  - condition: device
    device_id: 31ba7a43f840e195ee0463be0ae98c4c
    domain: vacuum
    entity_id: vacuum.natascha
    type: is_cleaning
  - device_id: 31ba7a43f840e195ee0463be0ae98c4c
    domain: vacuum
    type: dock
mode: single
This is just to see what I did as a test.
