'Imported' Tuya scene - how to delete?
I have a Tuya brand switch, which in the Tuya app I had a couple of scenes which I was running for a little while. I have since recreated the scenes in the HA Automation Editor, and deleted them from the Tuya app.
But, the app scenes remain in the HA entity register. I have an empty scenes.yaml file, so they must be stored elsewhere.
Is there any way to find and delete them?
Can you not delete them from the Entity registry? If not they may be stored on the switch. If so, you should be able to delete them from the app, I assume.
Thanks for the reply.
I can delete them from the Entity Registry, but it says that it won’t be deleted from HA. I assume this means it will remove it from the front-end, but not the back-end.
This will be my last resort, if I can’t find it’s source.
It have already deleted them from the app, which I assume also means the device itself. The app also has a clear cache feature which I have cleared without affect.
Did you solve this problem? I have the same issue.
I know this is very old, but I have the same problem and I’m using a very recent version of HA (2022.10.5).
Did you solve this some way?
I’ve tried exactly the same things… =/
Sorry, but it was so long ago I can’t remember how this ended.
I don’t think it’s a problem for me anymore.
I am having the same issue.
The scene is deleted from the Tuya-app but remains in Home Assistant somewhere.
I can’t even disable it from the dashboard. Annoying.
Any updates on this? Anything? Can I go into a file and delete this stuff?
