For some reason, my brand new (but hours of work) Home Assistant deployment on Raspberry Pi 4 using OS installl method (recommended) now fails.
I am unable to get past “Loading data” in the web browser, and I figured out how to get ahold of the core logs, which I paste below. It seems there is a problem with numpy, but I can’t figure out how to fix it…
Any suggestion would be welcome!
Log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/stream/core.py:15
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:53:03 AM (7 occurrences)
Last logged: 1:09:33 AM
[548012963200] Error handling message: Unknown error (unknown_error) Vincent Rioux from 192.168.150.160 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36 Edg/112.0.1722.48)
[547995407440] Error handling message: Unknown error (unknown_error) Vincent Rioux from fe80::dfb1:ac1e:a8:a74f (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36 Edg/112.0.1722.48)
[548078995824] Error handling message: Unknown error (unknown_error) Vincent Rioux from fe80::dfb1:ac1e:a8:a74f (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36 Edg/112.0.1722.48)
[547997935904] Error handling message: Unknown error (unknown_error) Vincent Rioux from fe80::dfb1:ac1e:a8:a74f (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36 Edg/112.0.1722.48)
[548013489936] Error handling message: Unknown error (unknown_error) Vincent Rioux from fe80::dfb1:ac1e:a8:a74f (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36 Edg/112.0.1722.48)
File "/usr/local/lib/python3.10/site-packages/numpy/core/__init__.py", line 23, in <module>
from . import multiarray
File "/usr/local/lib/python3.10/site-packages/numpy/core/multiarray.py", line 10, in <module>
from . import overrides
File "/usr/local/lib/python3.10/site-packages/numpy/core/overrides.py", line 6, in <module>
from numpy.core._multiarray_umath import (
ImportError: Error loading shared library _LR: No such file or directory (needed by /usr/local/lib/python3.10/site-packages/numpy/core/../../numpy.libs/libopenblas_armv8p-r0-8b2c479e.3.20.so)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 351, in handle_get_services
descriptions = await async_get_all_descriptions(hass)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 585, in async_get_all_descriptions
contents = await hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 553, in _load_services_files
return [_load_services_file(hass, integration) for integration in integrations]
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 553, in <listcomp>
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 535, in _load_services_file
_SERVICES_SCHEMA(load_yaml(str(integration.file_path / "services.yaml"))),
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 387, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
return schema(data)
return schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 636, in validate_sequence
cval = validate(index_path, value)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 229, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 353, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 140, in validate_supported_feature
return _validate_option_or_feature(supported_feature, "supported feature")
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 115, in _validate_option_or_feature
base_components = _base_components()
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 68, in _base_components
from homeassistant.components import (
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 30, in <module>
from homeassistant.components.stream import (
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 61, in <module>
from .core import (
File "/usr/src/homeassistant/homeassistant/components/stream/core.py", line 15, in <module>
import numpy as np
File "/usr/local/lib/python3.10/site-packages/numpy/__init__.py", line 140, in <module>
from . import core
File "/usr/local/lib/python3.10/site-packages/numpy/core/__init__.py", line 49, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.10 from "/usr/local/bin/python3"
* The NumPy version is: "1.23.2"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: Error loading shared library _LR: No such file or directory (needed by /usr/local/lib/python3.10/site-packages/numpy/core/../../numpy.libs/libopenblas_armv8p-r0-8b2c479e.3.20.so)
