Importing or restoring regions to owntracks
You can export regions from owntracks. but you can import. It would be helpful to be able to use previously exported regions to rebuild the list of regions that is lost when either owntracks or Home assistant is restarted
So what are you asking for?
another type on my part. should be.
You can export regions from owntracks. but you can’t import.regions/waypoints that were previously exported It would be helpful to be able to use previously exported regions to rebuild the list of regions that is lost when either owntracks or Home assistant is restarted
I
