This guide aggregates guides from a bunch of different places on how to connect rf based energy monitors such as the BLI-28000 from Blueline. Keep in mind this does the same thing as Home Assistant Glow but makes use of the old power cost monitors that were given out by certain utilities. They’re still available for purchase on eBay too and have nice weather proof containers.
Start: You will need:
- Working HASS install on something with at least 1 USB port
- Power cost monitor or similar (the black and decker one is also supported as it is functionally identical)
- rf receiver supported by RTL_433, try to get one that has an antenna or has decent sensitivity. You can find this by searching for RTL SDR and look for the one that has a specific Realtek chip, more info on the RTL_433 site
Part 1: Configure RTL_433 to decode your power cost monitor
Setup RTL_433 depending on your system, on windows you will need zadig and the RTL_433 binaries available from the GitHub here : Releases · merbanan/rtl_433 · GitHub
Use Zadig to install the winusb drivers (VERY IMPORTANT: MAKE SURE YOU INSTALL THE DRIVERS FOR THE CORRECT DEVICE, if you choose the wrong device zadig will replace the driver for that and it will likely stop working)
On windows you will also need Visual C++ etc. if you get some dll errors
Run the static binary with command -R 176:auto
Push the reset button on the power cost monitor, you should see a bunch of messages with an id number on your screen.
Note the id number, and run the binary again with command -R 176:[your id number]
You should now see a bunch of messages with the gap: value. This is the number of milliseconds it for the meter to use up it’s kh value. For example, with a kh value of 1, you would use this formula to calculate the current power consumption in kilowatts: 3600/gap
From this point out do not reset the monitor as it will also reset the ID. If you intend to use the standalone unit you should have it reset together at this step
Part 2: Setup RTL on HASS with MQTT
You can take your pick of add-on, personally I just used the MQTT add-on in the supervisor and RTL_433 to MQTT add-on here: rtl_433-hass-addons/rtl_433 at main · pbkhrv/rtl_433-hass-addons · GitHub
Install both, if you need a hand at this step, go to each ones respective guides. Of note, do not configure the integration for the MQTT add-on until you are sure the config file is done. I don’t know why but it refuses to work for me unless you add the user and password other than homeassistant and addon before configuring the integration.
Create an RTL_433 conf file, you can see examples on the GitHub and instructions on the RTL_433 to MQTT add-on page. MOst importantly make sure the protocol is enabled with protocol 176:[your id number] and output is configured to mqtt with the correct user and password. You can also specify a topic to publish to with the device parameter
Start the MQTT add-on, then the RTL_433 add-on. Check the logs for both and make sure MQTT add-on shows that RTL_433 has connected without socket errors, and the RTL_433 add-on ends with the line connection established. If this is not the case you need to troubleshoot the network connection. Make sure the IPs, ports, and usernames are correct.
Use an app like MQTT explorer to make sure you are getting output from RTL_433, you are looking for the topic with RTL433 or whatever you set it to, the under that you want the “gap”
Configure the integration For MQTT under HASS. Then make sure it is connected properly you should see in the log For MQTT that it’s connected under user homeassistant
Part 3: Pulling everything into HASS
First setup a sensor for the current power consumption in kilowatts:
- platform: mqtt
name: "Current Power Consumption" # pick whatever name you want
unique_id: "powerccostmon1" # this must be unique
state_topic: "rtl_433/BluelinePower/gap" #this is the topic you saw with MQTT explorer for the gap value
unit_of_measurement: 'kW'
value_template: "{{ '%.2f'%(3600 / (value | float)) | float }}" # if your meter's kH value is not 1, change the 3600 to whatever 3600*Kh is equal to.
device_class: energy
state_class: measurement
Next ensure that your sensor is working in homeassistant, check entities and make sure it’s reporting values.
Home assistant energy requires the total kWh as an entity as far as I’m aware. So to get this use the Riemann integration sensor:
- platform: integration
name: "Total Home Energy"
source: sensor.current_power_consumption
round: 3
unit: kWh
this will give you the total power consumption in kWh.
In order for the sensor to show up in energy you need to add the following attributes to the sensor: (Note see the Andrew Jones comment below before adding this part)
sensor.total_home_energy:
last_reset: "2020-01-01T00:00:00+00:00"
to do so, you can use customize by adding the following to configuration.yaml:
homeasisstant:
customize: !include customize.yaml
and in customize.yaml:
Now go to your energy dashboard, add consumption, and total home energy should show as an option, simply add it and wait, that’s it!
Credit to all of the following wonderful guides and discussions:
If I made any errors please feel free to update. I’m also working on figuring out how to make an entity to track the peak time costs and whether the energy dashboard will actually update properly as it still seems to be showing zero, any tips please message!
