Imposible to add a widget
Hi :slight_smile:
At home, we have 2 Samsung Galaxy S9+ with the same OS / update.
I can create and use widget from HA (I use many since years, as switchs).
On my wife’s phone, I want to create some a first one.
I do same… then the widget is empty, not working.
I found on google that DATA SAVER (in the device) should be disable. Is it, we never used it.
HA and compagnon app are up to date.
Please do you have any idea?
Thank you.
Is the companion app working normally on the device where you find the widget issue? When you sign in to the companion app with your HA account, is it the same account as the other phone that does work normally?
Nick
The app seems to work well.
No, my wife uses her account on her phone, mine on my phone.
It’s impossible to add widget on her phone.
Thank you :slight_smile:
Please provide screenshots and maybe a bug log. Something doesn’t seem right. Every user should be able to create widgets.
This is the problem :
1 - creating the widget
2 - confirming the size/place of the widget (with the wrong icon)
3 - result when I click on it
4 - when I edit the widget, it’s empty
Where can I find this log?
Settings > companion app> troubleshooting> show and share logs
You’ll want to recreate the issue so we can see the logs with the data saving and sending. Keep in mind the looks may contain gps and URL that you may want to mask.
Please find the end of the log at the moment I tried to add the widget.
05-15 13:19:46.194 13801 13801 V InputMethodManager: Not IME target window, ignoring
05-15 13:19:46.209 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: Relayout returned: old=(0,84,1440,2792) new=(291,637,1384,1475) req=(1093,838)0 dur=10 res=0x7 s={true 479110324224} ch=true
05-15 13:19:46.212 13801 16658 I mali_winsys: new_window_surface() [1317x1062] return: 0x3000
05-15 13:19:46.215 13801 13801 D AbsListView:  in onLayout changed
05-15 13:19:46.229 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: MSG_RESIZED: frame=(291,637,1384,1475) ci=(0,0,0,0) vi=(0,0,0,0) or=1
05-15 13:19:46.237 13801 13801 E SpannableStringBuilder: SPAN_EXCLUSIVE_EXCLUSIVE spans cannot have a zero length
05-15 13:19:46.241 13801 13801 I chatty  : uid=10215(io.homeassistant.companion.android) identical 2 lines
05-15 13:19:46.241 13801 13801 E SpannableStringBuilder: SPAN_EXCLUSIVE_EXCLUSIVE spans cannot have a zero length
05-15 13:19:48.021 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: Relayout returned: old=(291,637,1384,1475) new=(291,637,1384,1475) req=(1093,838)0 dur=6 res=0x1 s={true 479110324224} ch=false
05-15 13:19:48.233 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: Relayout returned: old=(291,637,1384,1475) new=(291,637,1384,1475) req=(1093,838)0 dur=7 res=0x1 s={true 479110324224} ch=false
05-15 13:19:48.780 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: Relayout returned: old=(291,637,1384,1475) new=(291,637,1384,973) req=(1093,336)0 dur=8 res=0x21 s={true 479110324224} ch=false
05-15 13:19:48.781 13801 16658 I mali_egl: eglDestroySurface() in
05-15 13:19:48.782 13801 13801 D AbsListView:  in onLayout changed
05-15 13:19:48.783 13801 16658 I mali_winsys: delete_surface() [1317x1062] return
05-15 13:19:48.783 13801 16658 I mali_egl: eglDestroySurface() out
05-15 13:19:48.783 13801 16658 W libEGL  : EGLNativeWindowType 0x70ad368250 disconnect failed
05-15 13:19:48.784 13801 16658 I mali_winsys: new_window_surface() [1317x560] return: 0x3000
05-15 13:19:48.795 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: MSG_RESIZED: frame=(291,637,1384,973) ci=(0,0,0,0) vi=(0,0,0,0) or=1
05-15 13:20:04.837 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: ViewPostIme pointer 0
05-15 13:20:04.913 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: ViewPostIme pointer 1
05-15 13:20:04.913 13801 13801 D AbsListView: onTouchUp() mTouchMode : 0
05-15 13:20:04.986 13801 16658 I mali_egl: eglDestroySurface() in
05-15 13:20:04.988 13801 16658 I mali_winsys: delete_surface() [1317x560] return
05-15 13:20:04.988 13801 16658 I mali_egl: eglDestroySurface() out
05-15 13:20:04.988 13801 16658 W libEGL  : EGLNativeWindowType 0x6f901d88d0 disconnect failed
05-15 13:20:04.988 13801 16658 D OpenGLRenderer: endAllActiveAnimators on 0x6f3b567d00 (DropDownListView) with handle 0x6f98193740
05-15 13:20:04.988 13801 13801 I ViewRootImpl@6fad21f[PopupWindow:fa4a940]: dispatchDetachedFromWindow
05-15 13:20:04.995 13801 13801 D InputTransport: Input channel destroyed: '552bc25', fd=219
05-15 13:20:05.012 13801 13801 E SpannableStringBuilder: SPAN_EXCLUSIVE_EXCLUSIVE spans cannot have a zero length
05-15 13:20:07.930 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: ViewPostIme pointer 0
05-15 13:20:07.994 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: ViewPostIme pointer 1
05-15 13:20:08.003 13801 13801 D Dialog  : mIsSamsungBasicInteraction = false
05-15 13:20:08.003 13801 13801 D Dialog  : mIsSamsungBasicInteraction = false, isMetaDataInActivity = false
05-15 13:20:08.008 13801 13801 I MultiWindowDecorSupport: [INFO] isPopOver = false
05-15 13:20:08.008 13801 13801 I MultiWindowDecorSupport: updateCaptionType >> DecorView@b90a5d[], isFloating: true, isApplication: true, hasWindowDecorCaption: false, hasWindowControllerCallback: false
05-15 13:20:08.008 13801 13801 D MultiWindowDecorSupport: setCaptionType = 0, DecorView = DecorView@b90a5d[]
05-15 13:20:08.020 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: setView = com.android.internal.policy.DecorView@b90a5d TM=true MM=false
05-15 13:20:08.122 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: Relayout returned: old=(0,84,1440,2792) new=(72,563,1368,2313) req=(1296,1750)0 dur=11 res=0x7 s={true 479110324224} ch=true
05-15 13:20:08.124 13801 16658 I mali_winsys: new_window_surface() [1520x1974] return: 0x3000
05-15 13:20:08.128 13801 13801 E DecorView: mWindow.mActivityCurrentConfig is null
05-15 13:20:08.142 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
05-15 13:20:08.142 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@b90a5d[ButtonWidgetConfigureActivity]
05-15 13:20:08.142 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:08.143 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@b90a5d[ButtonWidgetConfigureActivity]
05-15 13:20:08.143 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:08.143 13801 13801 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=null mNaviBarColor -15658735 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
05-15 13:20:08.143 13801 13801 D InputMethodManager: startInputInner - Id : 0
05-15 13:20:08.143 13801 13801 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
05-15 13:20:08.176 13801 13801 D InputTransport: Input channel destroyed: 'ClientS', fd=220
05-15 13:20:08.189 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(72,563,1368,2313) ci=(0,0,0,0) vi=(0,0,0,0) or=1
05-15 13:20:08.189 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(72,84,1368,1834) ci=(0,0,0,0) vi=(0,0,0,359) or=1
05-15 13:20:08.189 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
05-15 13:20:08.190 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@e659666[ButtonWidgetConfigureActivity]
05-15 13:20:08.190 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:08.265 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(0,0,1440,2960) ci=(0,84,0,168) vi=(0,84,0,168) or=1
05-15 13:20:08.285 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)0 dur=2 res=0x1 s={true 479153594368} ch=false
05-15 13:20:08.289 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(72,563,1368,2313) ci=(0,0,0,0) vi=(0,0,0,0) or=1
05-15 13:20:08.533 13801 13829 I mpanion.androi: Background concurrent copying GC freed 83666(6693KB) AllocSpace objects, 1(96KB) LOS objects, 49% free, 11MB/23MB, paused 331us total 132.880ms
05-15 13:20:08.633 13801 13801 E DecorView: mWindow.mActivityCurrentConfig is null
05-15 13:20:09.241 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: ViewPostIme pointer 0
05-15 13:20:09.280 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: ViewPostIme pointer 1
05-15 13:20:09.291 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@b90a5d[ButtonWidgetConfigureActivity]
05-15 13:20:09.291 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:09.291 13801 13801 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=androidx.compose.ui.text.input.NullableInputConnectionWrapperApi25@81b8fb1 mNaviBarColor -15658735 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
05-15 13:20:09.291 13801 13801 D InputMethodManager: startInputInner - Id : 0
05-15 13:20:09.296 13801 13801 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
05-15 13:20:09.298 13801 13801 D InputTransport: Input channel destroyed: 'ClientS', fd=219
05-15 13:20:09.298 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@b90a5d[ButtonWidgetConfigureActivity]
05-15 13:20:09.298 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:09.298 13801 13801 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=androidx.compose.ui.text.input.NullableInputConnectionWrapperApi25@b9c8017 mNaviBarColor -15658735 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
05-15 13:20:09.298 13801 13801 D InputMethodManager: startInputInner - Id : 0
05-15 13:20:09.299 13801 13801 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
05-15 13:20:09.300 13801 13801 D InputTransport: Input channel destroyed: 'ClientS', fd=220
05-15 13:20:09.309 13801 13801 D InputMethodManager: SSI - flag : 0 Pid : 13801 view : io.homeassistant.companion.android
05-15 13:20:09.309 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@b90a5d[ButtonWidgetConfigureActivity]
05-15 13:20:09.309 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:09.314 13801 13801 W IInputConnectionWrapper: getExtractedText on inactive InputConnection
05-15 13:20:09.325 13801 13801 W IInputConnectionWrapper: getTextBeforeCursor on inactive InputConnection
05-15 13:20:09.422 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(0,0,1440,2960) ci=(0,84,0,1485) vi=(0,84,0,1485) or=1
05-15 13:20:09.422 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(72,84,1368,1834) ci=(0,0,0,0) vi=(0,0,0,359) or=1
05-15 13:20:09.436 13801 13801 E DecorView: mWindow.mActivityCurrentConfig is null
05-15 13:20:09.446 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)0 dur=4 res=0x1 s={true 479153594368} ch=false
05-15 13:20:10.539 13801 13829 I mpanion.androi: Background young concurrent copying GC freed 132616(11MB) AllocSpace objects, 0(0B) LOS objects, 41% free, 13MB/23MB, paused 564us total 102.420ms
05-15 13:20:15.076 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: ViewPostIme pointer 0
05-15 13:20:15.150 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: ViewPostIme pointer 1
05-15 13:20:15.166 13801 16658 I mali_egl: eglDestroySurface() in
05-15 13:20:15.169 13801 16658 I mali_winsys: delete_surface() [1520x1974] return
05-15 13:20:15.169 13801 16658 I mali_egl: eglDestroySurface() out
05-15 13:20:15.169 13801 16658 W libEGL  : EGLNativeWindowType 0x6f901d88d0 disconnect failed
05-15 13:20:15.170 13801 13801 I ViewRootImpl@bb8eab8[ButtonWidgetConfigureActivity]: dispatchDetachedFromWindow
05-15 13:20:15.179 13801 13801 W InputEventReceiver: Attempted to finish an input event but the input event receiver has already been disposed.
05-15 13:20:15.179 13801 13801 D InputTransport: Input channel destroyed: '42c0860', fd=210
05-15 13:20:15.184 13801 13801 D InputMethodManager: HSIFW - flag : 0
05-15 13:20:15.184 13801 13801 I InputMethodManager: hideSoftInputFromWindow ignore mServedView == null or mServedView.getWindowToken() != windowToken, mServedView :0
05-15 13:20:15.186 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
05-15 13:20:15.186 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@e659666[ButtonWidgetConfigureActivity]
05-15 13:20:15.186 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:15.193 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@e659666[ButtonWidgetConfigureActivity]
05-15 13:20:15.193 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:15.193 13801 13801 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=androidx.emoji2.viewsintegration.EmojiInputConnection@cbfb00 mNaviBarColor -15658735 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
05-15 13:20:15.193 13801 13801 D InputMethodManager: startInputInner - Id : 0
05-15 13:20:15.197 13801 13801 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
05-15 13:20:15.199 13801 13801 D InputTransport: Input channel destroyed: 'ClientS', fd=219
05-15 13:20:15.200 13801 13801 E ViewRootImpl: sendUserActionEvent() mView returned.
05-15 13:20:15.207 13801 13801 E SpannableStringBuilder: SPAN_EXCLUSIVE_EXCLUSIVE spans cannot have a zero length
05-15 13:20:15.209 13801 13801 I chatty  : uid=10215(io.homeassistant.companion.android) identical 2 lines
05-15 13:20:15.209 13801 13801 E SpannableStringBuilder: SPAN_EXCLUSIVE_EXCLUSIVE spans cannot have a zero length
05-15 13:20:16.582 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: The input has been finished in ImeInputStage.
05-15 13:20:16.659 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: The input has been finished in ImeInputStage.
05-15 13:20:16.712 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_RESIZED: frame=(0,0,1440,2960) ci=(0,84,0,168) vi=(0,84,0,168) or=1
05-15 13:20:16.721 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)0 dur=2 res=0x1 s={true 479153594368} ch=false
05-15 13:20:17.520 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: ViewPostIme pointer 0
05-15 13:20:17.589 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: ViewPostIme pointer 1
05-15 13:20:17.630 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
05-15 13:20:17.630 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@e659666[ButtonWidgetConfigureActivity]
05-15 13:20:17.631 13801 13801 D InputMethodManager: getNavigationBarColor() -15658735
05-15 13:20:17.739 13801 13801 D InputTransport: Input channel destroyed: 'ClientS', fd=210
05-15 13:20:18.052 13801 16658 I mali_egl: eglDestroySurface() in
05-15 13:20:18.055 13801 16658 I mali_winsys: delete_surface() [1440x2960] return
05-15 13:20:18.055 13801 16658 I mali_egl: eglDestroySurface() out
05-15 13:20:18.055 13801 16658 W libEGL  : EGLNativeWindowType 0x7019e19290 disconnect failed
05-15 13:20:18.059 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)8 dur=3 res=0x5 s={false 0} ch=true
05-15 13:20:18.060 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: stopped(true) old=false
05-15 13:20:18.071 13801 13801 I ViewRootImpl@3766516[ButtonWidgetConfigureActivity]: dispatchDetachedFromWindow
05-15 13:20:18.078 13801 13801 D InputTransport: Input channel destroyed: 'c3d56c9', fd=208
05-15 13:20:18.803 13801 13801 D ButtonWidget: Broadcast received:
05-15 13:20:18.803 13801 13801 D ButtonWidget: Broadcast action: android.appwidget.action.APPWIDGET_UPDATE_OPTIONS
05-15 13:20:18.803 13801 13801 D ButtonWidget: AppWidgetId: 29
05-15 13:20:21.476 13801 13801 D ButtonWidget: Broadcast received:
05-15 13:20:21.476 13801 13801 D ButtonWidget: Broadcast action: io.homeassistant.companion.android.widgets.button.ButtonWidget.CALL_SERVICE
05-15 13:20:21.476 13801 13801 D ButtonWidget: AppWidgetId: 29
05-15 13:20:21.477 13801 13801 D ButtonWidget: Calling widget action
05-15 13:20:21.481 13801 13801 D ButtonWidget$callConfiguredAction: Action Call Data loaded:
05-15 13:20:21.481 13801 13801 D ButtonWidget$callConfiguredAction: domain: null
05-15 13:20:21.481 13801 13801 D ButtonWidget$callConfiguredAction: action: null
05-15 13:20:21.481 13801 13801 D ButtonWidget$callConfiguredAction: action_data: null
05-15 13:20:21.481 13801 13801 W ButtonWidget$callConfiguredAction: Action Call Data incomplete.  Aborting action call
05-15 13:20:22.975 13801 13801 D ButtonWidget: Broadcast received:
05-15 13:20:22.975 13801 13801 D ButtonWidget: Broadcast action: io.homeassistant.companion.android.widgets.button.ButtonWidget.RECEIVE_DATA
05-15 13:20:22.975 13801 13801 D ButtonWidget: AppWidgetId: 29
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: Saving action call config data:
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: domain: switch
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: action: toggle
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: action_data: {"entity_id":["switch.lampe_sdb_spot_sm7"]}
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: require_authentication: false
05-15 13:20:22.976 13801 13801 D ButtonWidget$saveActionCallConfiguration: label:
05-15 13:20:23.659 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)4 dur=8 res=0x1 s={false 0} ch=false
05-15 13:20:23.659 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: stopped(false) old=true
05-15 13:20:23.662 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: stopped(false) old=false
05-15 13:20:23.665 13801 13801 D IntegrationRepositoryImpl: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1747304362574, currentMillis: 1747304423665)
05-15 13:20:23.674 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)0 dur=5 res=0x7 s={true 479153594368} ch=true
05-15 13:20:23.677 13801 16658 I mali_winsys: new_window_surface() [1440x2960] return: 0x3000
05-15 13:20:23.690 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
05-15 13:20:23.690 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@ee58a82[SettingsActivity]
05-15 13:20:23.690 13801 13801 D InputMethodManager: getNavigationBarColor() -14935012
05-15 13:20:23.690 13801 13801 D IntegrationRepositoryImpl: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1747304362574, currentMillis: 1747304423690)
05-15 13:20:23.690 13801 13801 D IntegrationRepositoryImpl: setAppActive(): true
05-15 13:20:23.691 13801 13801 D InputMethodManager: prepareNavigationBarInfo() DecorView@ee58a82[SettingsActivity]
05-15 13:20:23.691 13801 13801 D InputMethodManager: getNavigationBarColor() -14935012
05-15 13:20:23.691 13801 13801 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=null mNaviBarColor -14935012 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
05-15 13:20:23.691 13801 13801 D InputMethodManager: startInputInner - Id : 0
05-15 13:20:23.691 13801 13801 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
05-15 13:20:24.341 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: ViewPostIme pointer 0
05-15 13:20:24.347 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: ViewPostIme pointer 1
05-15 13:20:24.347 13801 13801 E mpanion.androi: Invalid ID 0x00000000.
05-15 13:20:24.369 13801 13801 D ScrollView: initGoToTop
05-15 13:20:24.396 13801 13801 I ViewRootImpl@3ffb078[SettingsActivity]: Relayout returned: old=(0,0,1440,2960) new=(0,0,1440,2960) req=(1440,2960)0 dur=4 res=0x1 s={true 479153594368} ch=false
05-15 13:20:24.396 13801 13801 D ScrollView:  onsize change changed
05-15 13:20:24.400 13801 14131 D LogcatReader$readLog: Read logcat for pid 13801
