hello !
I just bought a domain name and i try to configure cloudflare so that i can access my HA from outside… i am connecting using starlink and i read the ip adress is not fix so i this is the way i found by looking over the internet…
so i followed a tuto (but i dont understand anything to this process)
i changed the serveurs name on the domain name provider
i added a few lines to the config.yaml :
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- 172.30.33.3
and i configured the cloudflare addon and put my domain name:
here is the addon log:
Add-on: Cloudflared
Use a Cloudflare Tunnel to remotely connect to Home Assistant without opening any ports
Add-on version: 5.1.1
You are running the latest version of this add-on.
System: Home Assistant OS 11.4 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2024.1.5
Home Assistant Supervisor: 2023.12.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[10:34:39] INFO: Checking add-on config…
[10:34:40] INFO: Checking for existing certificate…
[10:34:40] INFO: Existing certificate found
[10:34:40] INFO: Checking for existing tunnel…
[10:34:40] INFO: Existing tunnel with ID d2930ad0-a8ec-4485-a255-d4b1116786cd found
[10:34:40] INFO: Checking if existing tunnel matches name given in config
[10:34:43] INFO: Existing Cloudflare Tunnel name matches config, proceeding with existing tunnel file
[10:34:43] INFO: Creating config file…
[10:34:43] INFO: Validating config file…
Validating rules from /tmp/config.json
OK
[10:34:44] INFO: Creating DNS entry XXXXXXXX.fr…
2024-01-29T09:34:45Z INF xxxxxxxxxx.fr is already configured to route to your tunnel tunnelID=d2930ad0-a8ec-4485-a255-d4b1116786cd
[10:34:45] INFO: Finished setting up the Cloudflare Tunnel
[10:34:46] INFO: Connecting Cloudflare Tunnel…
2024-01-29T09:34:46Z INF Starting tunnel tunnelID=d2930ad0-a8ec-4485-a255-d4b1116786cd
2024-01-29T09:34:46Z INF Version 2024.1.5
2024-01-29T09:34:46Z INF GOOS: linux, GOVersion: go1.21.5, GoArch: arm64
2024-01-29T09:34:46Z INF Settings: map[config:/tmp/config.json cred-file:/data/tunnel.json credentials-file:/data/tunnel.json loglevel:info metrics:0.0.0.0:36500 no-autoupdate:true origincert:/data/cert.pem]
2024-01-29T09:34:46Z INF Generated Connector ID: c8ebad75-03c9-41ae-a2f6-82efb066429e
2024-01-29T09:34:46Z INF Initial protocol quic
2024-01-29T09:34:46Z INF ICMP proxy will use 172.30.33.3 as source for IPv4
2024-01-29T09:34:46Z INF ICMP proxy will use :: as source for IPv6
2024-01-29T09:34:46Z INF Starting metrics server on [::]:36500/metrics
2024-01-29T09:34:47Z INF Registered tunnel connection connIndex=0 connection=8745c869-ff39-4bda-bb21-f68cdad707f9 event=0 ip=198.41.200.33 location=mad04 protocol=quic
2024-01-29T09:34:48Z INF Registered tunnel connection connIndex=1 connection=4e8dde17-4d9a-43c4-be80-5b8887743c8a event=0 ip=198.41.192.27 location=bcn01 protocol=quic
2024-01-29T09:34:49Z INF Registered tunnel connection connIndex=2 connection=a0d64a85-06b7-46a3-bf90-55985d49a24a event=0 ip=198.41.200.193 location=mad01 protocol=quic
2024-01-29T09:34:50Z INF Registered tunnel connection connIndex=3 connection=0418cf2f-d582-4fe3-bd66-0918e1a5eb54 event=0 ip=198.41.192.37 location=bcn01 protocol=quic
Can anyone tell me why i get a 404: not found when i try to connect?
I followed the steps, tried to find on the internet why it is not working, but i cant find out…
would anyone be kind enough to help me please… i am really stucked…
If you need other info please let me know ![]()
