hello I am new to HA. please bear with me
trying to integrate a shelly module
a pop up comes up and ask for
host
port by default it shows 80 in the port
I have tried to add my fixed IP, my home IP, the shelly IP, any IP addresses on my homenetwork.
no luck
I am unsure what to do next
thanks for your help in advance
Is the IP from the Shelly
(HA and Shelly in the same network)
Hello gang…
New comer too…
I checked the various forums, threads, video, but no luck.
I am having the same problem setting up the Shelly integration.
I got everything recognized on my Shelly phone app. I got a Shelly 1 and a Shelly 1PM. every firmware up to date, latest version 2024.9 HA…
First, none of switches are automatically recognized by HA.
When wanting to add device… add integration… I get the picture above.
I tried entering the device IP address, HA address…
No luck.
Detail : my router is a Starlink and I can’t access it.
Tks for your suggestions.
HA address??? No
Put in the IP address from Shelly to Host and normaly the Port is 80
HA server in the same IP Range as the Shelly?
Pihole?
Firewall?
Hello:
Your comment on the «IP range » put me on the right track (Fiat Lux!)
My main LAN runs on 192.168.1. XXX (which contains HA on 192.168.1.94 IP address.
I have a switch that connects to a WAN (with Deco (TP-Link) wifi extenders) and all my wifi devices in the house are on IP addresses 192.168.68. XXX.
I did connect briefly HA to the wifi extender, and voila ! … device was discovered.
So you were absolutely right and thank you for your help.
That problem has kept me puzzled for a week.
