Hello, i have trouble to get Z2M to start properly.
I followed several tutorials and can find anyone with the same errors that i have, and my hair are starting to fall.
Here is my setup:
Sonoff ZBDongle-E (V2 model, EFR32MG21)
HA.OS v2024.10.0 which is running on RPI4 4GB
I flashed my sonoff dongle with this firmware (available on silabs-firmware-builder/firmware_builds/zbdonglee at main · darkxst/silabs-firmware-builder · GitHub):
ncp-uart-hw-v7.4.4.0-zbdonglee-115200.gbl
My Z2M config
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: mqtt_adm
password: ****
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240218114344-if00
adapter: ember
baudrate: 115200
rtscts: false
The error log i’m getting:
[14:53:55] INFO: Preparing to start...
[14:53:55] INFO: Socat not enabled
[14:53:58] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-10-04 14:54:04] info: z2m: Logging to console, file (filename: log.log)
[2024-10-04 14:54:04] info: z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-04 14:54:04] info: z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-04 14:54:05] info: zh:ember: Using default stack config.
[2024-10-04 14:54:05] info: zh:ember: ======== Ember Adapter Starting ========
[2024-10-04 14:54:05] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-10-04 14:54:05] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-04 14:54:05] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-10-04 14:54:05] info: zh:ember:uart:ash: Serial port opened
[2024-10-04 14:54:05] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-10-04 14:54:06] info: zh:ember:uart:ash: ======== ASH connected ========
[2024-10-04 14:54:06] info: zh:ember:uart:ash: ======== ASH started ========
[2024-10-04 14:54:06] info: zh:ember:ezsp: ======== EZSP started ========
[2024-10-04 14:54:06] info: zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2024-10-04 14:54:06] info: zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}
[2024-10-04 14:54:06] info: zh:ember: [STACK STATUS] Network up.
[2024-10-04 14:54:06] info: zh:ember: [INIT TC] Adapter network matches config.
[2024-10-04 14:54:06] info: zh:ember: [CONCENTRATOR] Started source route discovery. 1248ms until next broadcast.
[2024-10-04 14:54:06] info: z2m: zigbee-herdsman started (resumed)
[2024-10-04 14:54:06] info: z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":4,"revision":"7.4.4 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2024-10-04 14:54:06] info: z2m: Currently 0 devices are joined.
[2024-10-04 14:54:06] info: z2m: Zigbee: disabling joining new devices.
[2024-10-04 14:54:07] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-10-04 14:54:07] info: z2m: Connected to MQTT server
[2024-10-04 14:54:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
[2024-10-04 14:54:07] error: z2m: Failed to call 'Bridge' 'start' (TypeError: Cannot read properties of undefined (reading 'getDevice')
at Bridge.publishInfo (/app/lib/extension/bridge.ts:746:69)
at Bridge.start (/app/lib/extension/bridge.ts:174:20)
at Controller.callExtensions (/app/lib/controller.ts:399:17)
at Controller.start (/app/lib/controller.ts:218:9)
at start (/app/index.js:154:5))
[2024-10-04 14:54:07] info: z2m: Started frontend on port 8099
[2024-10-04 14:54:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":4,"revision":"7.4.4 [GA]","special":0,"type":170},"type":"EmberZNet"},"log_level":"info","network":{"channel":11,"extendedPanID":13368757625167469000,"panID":11483},"permit_join":false,"version":"1.40.2"}'
[2024-10-04 14:54:07] error: z2m: Failed to call 'HomeAssistant' 'start' (TypeError: Cannot read properties of undefined (reading 'deviceIeeeAddress')
at HomeAssistant.getBridgeEntity (/app/lib/extension/homeassistant.ts:2016:78)
at HomeAssistant.start (/app/lib/extension/homeassistant.ts:476:28)
[2024-10-04 14:54:07] info: z2m: Zigbee2MQTT started!
With this i can go to the web gui of z2m but i cant start pairing procedure, i tried many variations of configurations but none worked.
Am i missing something?
