And the home-assistant.log
2020-05-24 09:00:49 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-24 09:00:49 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-24 09:00:51 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=108 from 2020-05-24 08:45:05.252093)
2020-05-24 09:02:11 WARNING (MainThread) [homeassistant.setup] Setup of updater is taking over 10 seconds.
2020-05-24 09:02:13 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 184, in async_send_delete_message
alexa_entity = ENTITY_ADAPTERS[domain](hass, config, hass.states.get(entity_id))
File "/usr/src/homeassistant/homeassistant/components/alexa/entities.py", line 212, in __init__
self.entity_conf = config.entity_config.get(entity.entity_id, {})
AttributeError: 'NoneType' object has no attribute 'entity_id'
2020-05-24 09:02:17 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:02:17 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 5 seconds.
2020-05-24 09:03:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 150, in async_send_add_or_update_message
2020-05-24 09:06:05 ERROR (SyncWorker_4) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:06:05 ERROR (SyncWorker_1) [homeassistant.components.onkyo.media_player] Unable to connect to receiver at 192.168.0.12
2020-05-24 09:06:08 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:06:08 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 30 seconds.
2020-05-24 09:06:18 ERROR (MainThread) [homeassistant.components.automation] Shellies Discovery: Error executing script. Service not found for call_service at pos 1: Unable to find service python_script/shellies_discovery
2020-05-24 09:06:20 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:06:20 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 10 seconds.
2020-05-24 09:06:33 WARNING (MainThread) [homeassistant.helpers.translation] shelly: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-05-24 09:06:34 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:06:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 20 seconds.
2020-05-24 09:06:35 WARNING (MainThread) [homeassistant.helpers.translation] shelly: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-05-24 09:06:36 ERROR (SyncWorker_7) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:06:43 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:06:43 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 60 seconds.
2020-05-24 09:06:52 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 9 not ready after 30 seconds, continuing anyway
2020-05-24 09:06:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 9 Sensor (node_id: 9) not ready after 31 seconds, continuing anyway
2020-05-24 09:06:54 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 10 not ready after 32 seconds, continuing anyway
2020-05-24 09:06:54 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 10 Sensor (node_id: 10) not ready after 32 seconds, continuing anyway
2020-05-24 09:06:54 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Simon Unknown: type=0009, id=0000 Unknown (node_id: 11) not ready after 32 seconds, continuing anyway
2020-05-24 09:06:54 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 12 not ready after 32 seconds, continuing anyway
2020-05-24 09:06:54 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:06:55 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 40 seconds.
2020-05-24 09:06:56 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 12 Battery Level (node_id: 12) not ready after 30 seconds, continuing anyway
2020-05-24 09:07:07 ERROR (SyncWorker_7) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:07:36 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:07:36 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:07:38 ERROR (SyncWorker_11) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:07:48 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:07:48 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 90 seconds.
2020-05-24 09:08:09 ERROR (SyncWorker_9) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:08:40 ERROR (SyncWorker_10) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:08:57 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:08:57 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:09:11 ERROR (SyncWorker_19) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:09:24 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:09:24 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 120 seconds.
2020-05-24 09:09:42 ERROR (SyncWorker_11) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:10:13 ERROR (SyncWorker_11) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:10:18 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:10:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:10:29 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Received invalid webhook payload: required key not provided @ data[11]['state']. Got None
2020-05-24 09:10:29 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Received invalid webhook payload: required key not provided @ data[12]['state']. Got None
2020-05-24 09:10:44 ERROR (SyncWorker_17) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:11:15 ERROR (SyncWorker_8) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:11:29 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:11:29 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 150 seconds.
2020-05-24 09:11:40 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:11:40 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:11:46 ERROR (SyncWorker_8) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:12:17 ERROR (SyncWorker_9) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:12:48 ERROR (SyncWorker_12) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:13:01 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:13:01 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:13:19 ERROR (SyncWorker_17) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:13:50 ERROR (SyncWorker_7) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:14:04 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'ONVIF Camera', but will retry later. Error: Cannot connect to host 192.168.0.120:5000 ssl:None [Connect call failed ('192.168.0.120', 5000)]
2020-05-24 09:14:04 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 180 seconds.
2020-05-24 09:14:21 ERROR (SyncWorker_6) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
2020-05-24 09:14:22 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: Bad IPv4/UDP transport address BRW802BF96B94CA.local@161: [Errno -2] Name does not resolvecaused by <class 'socket.gaierror'>: [Errno -2] Name does not resolve
2020-05-24 09:14:22 WARNING (MainThread) [homeassistant.config_entries] Config entry for brother not ready yet. Retrying in 80 seconds.
2020-05-24 09:14:52 ERROR (SyncWorker_0) [homeassistant.components.scrape.sensor] Unable to extract data from HTML
And the system log in the supervisor
20-05-24 08:33:07 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.110.1
20-05-24 08:33:07 INFO (SyncWorker_18) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.109.0 to homeassistant/raspberrypi3-homeassistant:0.110.1
20-05-24 08:33:07 INFO (SyncWorker_18) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.110.1.
20-05-24 08:38:48 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-05-24 09:06:20 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-24 09:06:20 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.109.0
20-05-24 09:06:20 INFO (SyncWorker_17) [supervisor.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:0.110.1']
