The frontend needs a little bit of polish when it comes to Duration sensors.
Currently, if the duration is > 24 hours, it still only shows as either “HH:MM:SS” or HHH:MM:SS if the duration is really long…
It would be nice if it would show something like “D days, HH:MM” for longer durations.
Maybe even an option to skip seconds if more than X hours, skip minutes if more than Y days…
In a perfect world. this could be adjustible like other “Display precision”
And an improvement to the history chart would be if it showed the labels as the same (“D, HH:MM:SS”), not as the raw output from the sensor:
5000 minutes does not really say anything except “a pretty long time”
Be sure to vote for your own request! While the feature request of the site doesn’t equate to a to-do list for the devs, it will inspire others to either offer solutions or maybe write an extension.
You do have a couple of ways now of addressing this. One would be to use something like Multiple Entities Row in your dashboard because it offers a nice selection of automatically formatting your time:
Could be that it works better for durations > 24 hours, but I currently use a glance card for this so it would need some more work with the dashboard.
Or you could write a sensor template that fixes the number for you and just display that state instead.
That is what I currently do. But it is not ideal, especially since it does not solve the problem of the history view and statistics.
I think, for the first part, this only needs a little tweak here:
But I don’t know enough about the frontend here to be sure, so I can’t make a PR.
The history and more-info cards is way out of my league atm.
