Improve "ha backups" command
I have scheduled my HA-backups based on cron. So every day a fresh full backup is done. Works fine so far. It is just a little bit tricky to remove old backups this way!
The ha backups uses different naming schemes for newand remove.
What is meant by this? Example:
Creating a new backup I have to give it a name:
ha backups new --name cron_backup1
But to remove I have to give the “slug” value (filename):
ha backups remove d4aa34e2
This appears to be inconsistent. ha remove should be able to read the given name for a backup, too.
I am fully aware from point of coding it is the easiest way how it is implemented now. But is difficult if man want to automate…
Thanks!
/KNEBB
