there is a constant defining the maximum number or rows to be purged at a time. This constant is bound to some “old sqlite” version - while I am unsure how old that is. But maybe that limitation can be “improved” by now?
MAX_QUEUE_BACKLOG_MIN_VALUE = 65000
ESTIMATED_QUEUE_ITEM_SIZE = 10240
QUEUE_PERCENTAGE_ALLOWED_AVAILABLE_MEMORY = 0.65
# The maximum number of rows (events) we purge in one delete statement
# sqlite3 has a limit of 999 until version 3.32.0
# in https://github.com/sqlite/sqlite/commit/efdba1a8b3c6c967e7fae9c1989c40d420ce64cc
# We can increase this back to 1000 once most
# have upgraded their sqlite version
SQLITE_MAX_BIND_VARS = 998
DB_WORKER_PREFIX = "DbWorker"
ALL_DOMAIN_EXCLUDE_ATTRS = {ATTR_ATTRIBUTION, ATTR_RESTORED, ATTR_SUPPORTED_FEATURES}
ATTR_KEEP_DAYS = "keep_days"
ATTR_REPACK = "repack"
ATTR_APPLY_FILTER = "apply_filter"
KEEPALIVE_TIME = 30
Also: I am using an external mariadb which should not have that limitation. Maybe the number could be increased for non-sqlite setups?
thanks and keep up the great work!
edit:
sqlite version seems to be this:
>>> import sqlite3
>>> sqlite3.sqlite_version
'3.34.1'
edit2:
I did experiments within a test environment:
ha in vscode docker-dev-env
mariadb in docker (11.0.2-MariaDB-1:11.0.2+maria~ubu2204)
SQLITE_MAX_BIND_VARS = 50000
=> ERROR: The total number of locks exceeds the lock table size; purge_entity_data not completed.
This could be avoided by increasing innodb_buffer_pool_size - but there is no reason in adapting the config that that special purpose.
A value of 30000 worked, but was a bit slow.
A value of 20000 worked really good .
nickrout
(Nick Rout)
July 20, 2023, 10:52am
2
Change the number, test it, submit a PR.
I have do not have a sqlite database to test it with.
mariadb tests: see above.
PR here:
home-assistant:dev
← wuppiwuppi:increase_sqlite_max_binds
opened 03:02PM - 20 Jul 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue: https://community.home-assistant.io/t/improve-purging-speed-by-selecting-more-than-998-elements/593745
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
Testing on real sqlite needed.
Testing on RaspberryPi needed.
