I have been having some issues trigging scenes in my kitchen that has 9 hue bulbs. I have a motion sensor that triggers one of 3 different scenes depending on the time of the day. However about 60% of the time not al the bulbs come on, usually just 2 or 3 stay off. If I trigger the scene manually it seems to work.
I suspect the delay is more related to the Hue Bridge not being able to “process” all 9 lights in the correct color.
Is there a way I could improve this process to ensure all of the lights trigger properly.
For the best performance, you should use a Hue Scene. One broadcasted command serves to activate all members of the scene. In contrast, Home Assistant’s Scene sends a separate command to each member of the Scene.
I am activating a home assistant scene, i created them based on my scenes in Hue. I wasn’t even aware that you could activate a hue scene that does should like it could eliminate the issue.
