"in 12 hours"
Not sure what is wrong. All of my entities say “in 12 hours” as their history and have said this for hours. Cleared db, and logbook, as well as ran the recorder purges, still the same thing. Any ideas? Logbook is empty even if you look 12 hours ahead.
Sounds like your timezone is incorrectly set.
Shouldn’t be. It works fine on the instance I made the backup from. This is a fresh install on my new pi 400, just came in today, so I am migrating. I also literally just checked that and it shows mountain time. now() is reporting properly too, I have a lovelace/dashboard card that uses the now() template as a clock and it is accurate.
Update: It did move down to “in 11 hours” on most sensors, but not all.
Well, that was weird. Just all of a sudden started working after that last restart. I don’t think I changed anything, I was messing with a different PC, trying to load my VM to copy the db out of it into the new one, and before I got to that point, it was reporting properly again. It even filled in the history from the last 2 hours while I was trying to fix this.
