Question in subject.
Thank you.
Thank you.
You will have to merge them first in a merge node.
so if this is an example msg object that the switch node receives:
{ "payload": {
"id": "4",
"property": "scene"
is there a way to use a single jsonata expression or another way in rules for the switch node to evaluate if id
= “4” and property
= “scene”?
thanks.
figured it out. in the switch node set property to msg.payload
then change rule to jsonata expression
then this expression will evaluate to true
payload.id = "4" and payload.property = "scene"
